View the VRF Configurations
Use the following command to view VRF configurations.
View the VRF configuration:
Switch:1#show ip ospf vrf virtualrandf1
OSPF General - VRF virtualrandf1
RouterId: 192.0.2.1
AdminStat: disabled
VersionNumber: 2
AreaBdrRtrStatus: false
ASBdrRtrStatus: false
Bad-Lsa-Ignore: false
ExternLsaCount: 0
ExternLsaCksumSum: 0(0x0)
TOSSupport: 0
OriginateNewLsas: 0
RxNewLsas: 0
TrapEnable: false
AutoVirtLinkEnable: false
SpfHoldDownTime: 10
Rfc1583Compatibility: disable
default-metric :
ethernet - 100
--More-- (q = quit)
Variable definitions
The following table defines parameters for the show ip ospf vrf command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
